projects:crazyflie2:expansionboards:zranger [2017-03-14 13:43] tobias created |
projects:crazyflie2:expansionboards:zranger [2017-03-14 14:47] arnaud |
Line 6: | Line 6: | ||
- | * VL53L0x ToF sensor to measure distance up to 2 meters. | + | * [[http:// |
* 1-wire memory for automatic expansion deck detection | * 1-wire memory for automatic expansion deck detection | ||
* Designed for mounting under the Crazyflie 2.0 | * Designed for mounting under the Crazyflie 2.0 | ||
Line 18: | Line 18: | ||
===== Usage ===== | ===== Usage ===== | ||
+ | The Z-ranger deck will be automatically detected when it is mounted. By default the range is available on the log variable " | ||
+ | To enable altitude control using the Z-ranger, the Crazyflie firmware has to be recompiled with the following config.mk: | ||
+ | <file make config.mk> | ||
+ | ESTIMATOR=kalman | ||
+ | CFLAGS += -DUPDATE_KALMAN_WITH_RANGING -DKALMAN_DECOUPLE_XY | ||
+ | Once the recompiled firmware, precise height control using the altitude-hold mode. To activate precise height control press the [[https:// | ||
+ | The sensor can measure distances up to 2 meters but often fails at distances above 1.5m. In case of unreliable readings the Crazyflie 2.0 will slowly drift. If that happens bring it down to the detection range. | ||
+ | **Note: Currently the mobile clients does not support this functionality!** |
