Next revision | Previous revision Last revision Both sides next revision | ||
projects:crazyflie2:expansionboards:zranger [2017-03-14 13:43] tobias created |
projects:crazyflie2:expansionboards:zranger [2017-04-21 12:24] arnaud [Default usage] |
Line 6: | Line 6: | ||
- | * VL53L0x ToF sensor to measure distance up to 2 meters. | + | * [[http:// |
* 1-wire memory for automatic expansion deck detection | * 1-wire memory for automatic expansion deck detection | ||
* Designed for mounting under the Crazyflie 2.0 | * Designed for mounting under the Crazyflie 2.0 | ||
Line 17: | Line 17: | ||
Z-ranger expansion deck {{ : | Z-ranger expansion deck {{ : | ||
- | ===== Usage ===== | + | ===== Default usage ===== |
+ | To get started you can follow the [[https:// | ||
+ | The Z-ranger deck will be automatically detected when it is mounted. By default the range is available on the log variable " | ||
+ | The best way to use the Z-Ranger deck is to enable the [[doc: | ||
+ | ===== Usage with the experimental Kalman filter ===== | ||
+ | The Kalman filter is a sensor fusion algorithm that is still experimental. You can try it by recompiling the Crazyflie firmware. | ||
+ | To enable altitude control using the Z-ranger with the kalman filter, the Crazyflie firmware has to be recompiled with the following config.mk: | ||
+ | <file make config.mk> | ||
+ | ESTIMATOR=kalman | ||
+ | CFLAGS += -DUPDATE_KALMAN_WITH_RANGING -DKALMAN_DECOUPLE_XY | ||
+ | Once the recompiled firmware, precise height control using the altitude-hold mode. To activate precise height control press the [[https:// | ||
+ | The sensor can measure distances up to 2 meters but often fails at distances above 1.5m. In case of unreliable readings the Crazyflie 2.0 will slowly drift. If that happens bring it down to the detection range. | ||
+ | **Note: Currently the mobile clients does not support this functionality!** |
