projects:crazyflie2:expansionboards:zranger [2017-04-11 17:07] bjorn |
projects:crazyflie2:expansionboards:zranger [2017-04-21 12:17] tobias [Usage] |
Line 18: | Line 18: | ||
===== Usage ===== | ===== Usage ===== | ||
- | The Z-ranger deck will be automatically detected when it is mounted. By default the range is available on the log variable " | + | The Z-ranger deck will be automatically detected when it is mounted. By default the range is available on the log variable " |
- | The best way to use the Z-Ranger deck is to enable the [[doc: | + | The best way to use the Z-Ranger deck is to enable the [[doc: |
