projects:crazyflie2:expansionboards:zranger [2017-04-21 12:11] tobias [Usage] |
projects:crazyflie2:expansionboards:zranger [2021-06-24 16:13] kimberly |
====== Z-ranger expansion deck ====== | ====== Z-ranger expansion deck ====== | ||
Line 17: | Line 22: | ||
Z-ranger expansion deck {{ : | Z-ranger expansion deck {{ : | ||
- | ===== Usage ===== | + | ===== Default usage ===== |
+ | To get started you can follow the [[https:// | ||
The Z-ranger deck will be automatically detected when it is mounted. By default the range is available on the log variable " | The Z-ranger deck will be automatically detected when it is mounted. By default the range is available on the log variable " | ||
- | The best way to use the Z-Ranger deck is to enable the [[doc: | + | The best way to use the Z-Ranger deck is to enable the [[doc: |
