Both sides previous revision Previous revision | Last revision Both sides next revision | ||
projects:crazyflie2:expansionboards:zranger [2017-04-21 12:19] tobias [Standard usage] |
projects:crazyflie2:expansionboards:zranger [2017-04-21 12:24] arnaud [Default usage] |
Line 18: | Line 18: | ||
===== Default usage ===== | ===== Default usage ===== | ||
+ | To get started you can follow the [[https:// | ||
The Z-ranger deck will be automatically detected when it is mounted. By default the range is available on the log variable " | The Z-ranger deck will be automatically detected when it is mounted. By default the range is available on the log variable " | ||
