projects:crazyflie2:expansionboards:zranger [2017-03-14 14:20] tobias [Usage] |
projects:crazyflie2:expansionboards:zranger [2021-06-24 16:13] (current) kimberly |
| ====== Z-ranger expansion deck ====== | ====== Z-ranger expansion deck ====== | ||
| Line 17: | Line 22: | ||
| Z-ranger expansion deck {{ : | Z-ranger expansion deck {{ : | ||
| - | ===== Usage ===== | + | ===== Default usage ===== |
| - | The Z-ranger deck will be automatically detected when it is mounted. To activate precise height control press the [[https:// | + | |
| + | To get started you can follow the [[https:// | ||
| + | The Z-ranger deck will be automatically detected when it is mounted. By default the range is available on the log variable " | ||
| + | The best way to use the Z-Ranger deck is to enable the [[doc: | ||
| + | ===== Usage with the experimental Kalman filter ===== | ||
| + | The Kalman filter is a sensor fusion algorithm that is still experimental. You can try it by recompiling the Crazyflie firmware. | ||
| + | To enable altitude control using the Z-ranger with the kalman filter, the Crazyflie firmware has to be recompiled with the following config.mk: | ||
| + | <file make config.mk> | ||
| + | ESTIMATOR=kalman | ||
| + | CFLAGS += -DUPDATE_KALMAN_WITH_RANGING -DKALMAN_DECOUPLE_XY | ||
| + | Once the recompiled firmware, precise height control using the altitude-hold mode. To activate precise height control press the [[https:// | ||
| - | The sensor can measure distances up to 2 meters but often fails at distances above 1.5m. In case of unreliable readings the Crazyflie 2.0 will slowly | + | The sensor can measure distances up to 2 meters but often fails at distances above 1.5m. In case of unreliable readings the Crazyflie 2.0 will slowly |
| **Note: Currently the mobile clients does not support this functionality!** | **Note: Currently the mobile clients does not support this functionality!** | ||
