User Tools
Site Tools
projects:crazyflie2:expansionboards:zranger
Differences
Link to this comparison view
Next revision
Previous revision
projects:crazyflie2:expansionboards:zranger [2017-04-21 12:11]
tobias [Usage]
projects:crazyflie2:expansionboards:zranger [2021-06-24 16:13] (current)
Line 1: Line 1:
 +This page has deprecated and moved to the new documentation framework of the main Bitcraze website. Please go to [[https://www.bitcraze.io/]] and go to the menu 'products'.
 +</WRAP>
 ====== Z-ranger expansion deck ====== ====== Z-ranger expansion deck ======
Line 17: Line 22:
 Z-ranger expansion deck {{ :projects:crazyflie2:expansionboards:z-ranger_rev.b.pdf|schematic}} Z-ranger expansion deck {{ :projects:crazyflie2:expansionboards:z-ranger_rev.b.pdf|schematic}}
-===== Usage =====+===== Default usage =====
 +To get started you can follow the [[https://www.bitcraze.io/getting-started-with-z-ranger-deck/|Z-Ranger getting started guide]].
 The Z-ranger deck will be automatically detected when it is mounted. By default the range is available on the log variable "range.zrange" and is used instead of the pressure by internal algorithms. The Z-ranger deck will be automatically detected when it is mounted. By default the range is available on the log variable "range.zrange" and is used instead of the pressure by internal algorithms.
-The best way to use the Z-Ranger deck is to enable the [[doc:crazyflie:client:pycfclient:index#flightcontrol|Height-hold]] mode in the client. This requires the latest client and the latest firmware so make sure to update your Crazyflie.+The best way to use the Z-Ranger deck is to enable the [[doc:crazyflie:client:pycfclient:index#flightcontrol|Height-hold]] mode in the client. This requires at least client and firmware [[https://github.com/bitcraze/crazyflie-release/releases|2017.04]] so make sure to update your Crazyflie.
projects/crazyflie2/expansionboards/zranger.1492769509.txt.gz · Last modified: 2017-04-21 12:11 by tobias
