projects:crazyflie2:index [2014-09-23 18:28] macke created |
projects:crazyflie2:index [2020-05-12 14:56] (current) kimberly |
| - | ====== Crazyflie 2.0 ====== | + | <WRAP center round important 60%> |
| - | The Crazyflie 2.0 is a versatile flying development platform that only weights 27g and fits in the palm of your hand. | + | This page has deprecated |
| - | It's advanced functionalities makes it ideal for developers and the Bluetooth LE capabilities makes it easy to fly from mobile devices. | + | [[https:// |
| - | With it's small size and weight it's ideal for indoor use, but you can just as easily hover above your house as | + | </ |
| - | you can hover under your diningroom table. Designed as a solderless kit, the Crazyflie 2.0 is quickly assembled | + | |
| - | by attaching the motors to the circuitboard frame and it's ready to fly. | + | |
| - | **Features** | + | ====== Crazyflie 2.X ====== |
| - | * Durable design | + | |
| - | * Easy to assemble and no soldering required | + | |
| - | * Supports expansion boards with automatic detection | + | |
| - | * Supports flying from iOS and Android with Bluetooth LE support as well as from Windows/ | + | |
| - | * Tested to above 1 km radio range LOS with Crazyradio PA | + | |
| - | * Wireless firmware update | + | |
| - | * On-board charging via standard uUSB | + | |
| - | * Dual-MCU architecture with dedicated radio/power management SoC for advanced applications | + | |
| - | * Using Crazyradio or Crazyradio PA together with a computer the user can log/ | + | |
| - | For a full list of specifications | + | This page contains information about the hardware design and advanced development topics for the Crazyflie 2.X. |
| + | For specifications | ||
| + | * [[https:// | ||
| + | Before using the product please read the [[projects: | ||
| ===== Using ===== | ===== Using ===== | ||
| - | | + | * [[projects: |
| - | | + | * [[projects:crazyflie2:userguide:serial|Crazyflie 2.X serial]]: How to get the Crazyflie 2.X serial on different platforms |
| - | * [[projects:apps:ios: | + | |
| - | * [[projects: | + | |
| - | ===== Expansion boards | + | ===== Development |
| - | * [[projects: | + | *[[projects: |
| ===== Electronics ===== | ===== Electronics ===== | ||
| + | * [[projects: | ||
