projects:crazyflie2:index
Crazyflie 2.0
The Crazyflie 2.0 is a versatile flying development platform that only weights 27g and fits in the palm of your hand. It's advanced functionalities makes it ideal for developers and the Bluetooth LE capabilities makes it easy to fly from mobile devices. With it's small size and weight it's ideal for indoor use, but you can just as easily hover above your house as you can hover under your diningroom table. Designed as a solderless kit, the Crazyflie 2.0 is quickly assembled by attaching the motors to the circuitboard frame and it's ready to fly.
Features
  • Durable design
  • Easy to assemble and no soldering required
  • Supports expansion boards with automatic detection
  • Supports flying from iOS and Android with Bluetooth LE support as well as from Windows/MacOSX/Linux with the Crazyradio or Crazyradio PA
  • Tested to above 1 km radio range LOS with Crazyradio PA
  • Wireless firmware update
  • On-board charging via standard uUSB
  • Dual-MCU architecture with dedicated radio/power management SoC for advanced applications
  • Using Crazyradio or Crazyradio PA together with a computer the user can log/graph/set variables in real-time via the radio and make full use of the expansion boards
For a full list of specifications have a look here.
Using
  • Assembly instructions: Image and video showing how to assemble your Crazyflie 2.0. Read this before you start assembly!
  • Userguide: User guide showing the different parts of your Crazyflie 2.0, what the LED indications mean and how to get started using it
  • iOS userguide: Information and userguide for the iOS app used for flying from iPhone and iPad
  • Android userguide: Information, userguide and list of compatible devices for the Android app used for flying
Expansion boards
Electronics
  • Specification: The specification of the Crazyflie 2.0 hardware
  • Hardware deign: A more in-depth view of the Crazyflie 2.0 and the design of it
  • Schematics: Schematics of the Crazyflie 2.0
projects/crazyflie2/index.1411489701.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
