                    projects:crazyflie2:upgrading:index [2016-09-12 13:25] tobias  |
                — (current) | ||
| - | ====== Upgrading/ | ||
| - | The Crazyflie 2.0 contains two micro-controllers (nRF51, STM32F4) and upgrading/ | ||
| - | ==== Upgrade/ | ||
| - | The Crazyflie 2.0 contains a bootloader with which it can be used to updated both micro-controllers over the air (OTA). Either using the cfclient, apps or from command line. | ||
| - |   * [[doc: | ||
| - |   * Command line. Convenient for developers. This is also available as a make target in Eclipse in the [[projects: | ||
| - |   * [[https:// | ||
| - | Got to the upgrade tab in the settings menu of the app and follow the instructions. | ||
| - | Only the STM32F4 MCU can be flashed using dfu. Please see [[projects: | ||
| - | This is mainly for development and requires a JTAG debugger and an adapter to the Crazyflie 2.0 connector. | ||
