projects:crazyflie2:upgrading:index [2015-03-23 13:23] tobias [Upgrade/flash using the Crazyradio or Crazyradio PA] |
projects:crazyflie2:upgrading:index [2016-09-12 13:25] tobias |
+ | ====== Upgrading/ | ||
+ | The Crazyflie 2.0 contains two micro-controllers (nRF51, STM32F4) and upgrading/ | ||
+ | ==== Upgrade/ | ||
+ | The Crazyflie 2.0 contains a bootloader with which it can be used to updated both micro-controllers over the air (OTA). Either using the cfclient, apps or from command line. | ||
+ | * [[doc: | ||
+ | * Command line. Convenient for developers. This is also available as a make target in Eclipse in the [[projects: | ||
+ | * [[https:// | ||
+ | Got to the upgrade tab in the settings menu of the app and follow the instructions. | ||
+ | Only the STM32F4 MCU can be flashed using dfu. Please see [[projects: | ||
+ | This is mainly for development and requires a JTAG debugger and an adapter to the Crazyflie 2.0 connector. | ||
