projects:crazyflie2:upgrading:index [2016-01-29 01:25] fred |
— (current) | ||
| - | ====== Upgrading/ | ||
| - | The Crazyflie 2.0 contains two micro-controllers (nRF51, STM32F4) and upgrading/ | ||
| - | ==== Upgrade/ | ||
| - | The Crazyflie 2.0 contains a bootloader with which it can be used to updated both micro-controllers over the air (OTA). Either using the cfclient or from command line. | ||
| - | * [[doc: | ||
| - | * Command line. Convenient for developers. This is also available as a make target in Eclipse in the [[projects: | ||
| - | This is mainly for development and requires a JTAG debugger and an adapter to the Crazyflie 2.0 connector. | ||
| - | * [[https:// | ||
