projects:crazyflie:crtp:commander [2013-03-20 09:44] macke |
projects:crazyflie:crtp:commander [2021-06-24 16:54] kimberly |
====== Commander ====== | ====== Commander ====== | ||
The commander port is used to send control set-points for the roll/ | The commander port is used to send control set-points for the roll/ | ||
Line 4: | Line 7: | ||
- | | PITCH | | + | | ROLL | PITCH | YAW |THRUST | |
Length | Length | ||
Line 10: | Line 13: | ||
^ Name ^ Byte ^ Size ^ Type ^ Comment ^ | ^ Name ^ Byte ^ Size ^ Type ^ Comment ^ | ||
- | | PITCH | 0-3 | 4 | float | The pitch set-point | | + | | ROLL | 0-3 | 4 | float | The pitch set-point | |
- | | ROLL | 4-7 | 4 | float | The roll set-point | | + | | PITCH | 4-7 | 4 | float | The roll set-point | |
| YAW | 8-11 | 4 | float | The yaw set-point | | | YAW | 8-11 | 4 | float | The yaw set-point | | ||
| THRUST | 12-13 | 2 | uint16_t | The thrust set-point | | | THRUST | 12-13 | 2 | uint16_t | The thrust set-point | |
