projects:crazyflie:crtp [2013-02-22 07:24] macke |
projects:crazyflie:crtp [2013-04-02 15:41] arnaud [Layers] |
Line 22: | Line 22: | ||
- | <code> | + | <ditaa> |
Line 30: | Line 30: | ||
- | </code> | + | </ditaa> |
* **CRTP Link** is responsible for transferring the packets between the Crazyflie and the host. It will typically handles packet size and error detection. | * **CRTP Link** is responsible for transferring the packets between the Crazyflie and the host. It will typically handles packet size and error detection. | ||
Line 56: | Line 56: | ||
===== Serial port ===== | ===== Serial port ===== | ||
- | This is mostly for legacy support but has been used during development to log data at higher speeds. The support for using the serial port might be broken currently though. | + | The serial port is configured in 115200 8N1. CRTP packets are sent and received asynchronously |
+ | 7 | ||
+ | | Port | ||
+ | | DATA 0 | | ||
+ | | Cksum | | ||
- | ^ **Field** ^ **Byte** ^ | + | ^ **Field** ^ **Byte** ^ **Bit** ^ |
- | | Size | + | | ::: | |
- | | Data | + | | ::: | |
- | | CRC | + | | Size |
+ | | Data | ||
+ | | Cksum |
