projects:crazyflie:crtp [2013-04-02 15:36] arnaud [Serial port] |
projects:crazyflie:crtp [2021-06-24 16:48] (current) kimberly |
====== Crazy RealTime Protocol ====== | ====== Crazy RealTime Protocol ====== | ||
The protocol used to communicate with the Crazyflie is called the Crazy RealTime Protocol, or CRTP in short. It's a simple protocol mainly designed to suit the radio chip used on the Crazyflie but the protocol can also be used on other physical links. | The protocol used to communicate with the Crazyflie is called the Crazy RealTime Protocol, or CRTP in short. It's a simple protocol mainly designed to suit the radio chip used on the Crazyflie but the protocol can also be used on other physical links. | ||
Line 22: | Line 25: | ||
- | <code> | + | <ditaa> |
Line 30: | Line 33: | ||
- | </code> | + | </ditaa> |
* **CRTP Link** is responsible for transferring the packets between the Crazyflie and the host. It will typically handles packet size and error detection. | * **CRTP Link** is responsible for transferring the packets between the Crazyflie and the host. It will typically handles packet size and error detection. | ||
Line 44: | Line 47: | ||
Line 54: | Line 58: | ||
===== USB port ===== | ===== USB port ===== | ||
This is currently not implemented but it will potentially replace the serial port link. The use of this is to get CRTP at higher speeds than the radio can transmit. | This is currently not implemented but it will potentially replace the serial port link. The use of this is to get CRTP at higher speeds than the radio can transmit. | ||
+ | ===== Serial port ===== | ||
Line 69: | Line 76: | ||
- | | DATA 30 | | ||
| Cksum | | | Cksum | | ||
Line 89: | Line 94: | ||
+ | ==== Example ==== | ||
+ | To send setpoints to the [[projects: | ||
+ | 0xaa 0xaa 0x30 0x0e 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3e | ||
+ | To ping Crazyflie: | ||
