Next revision | Previous revision Last revision Both sides next revision | ||
projects:crazyflie:crtp [2013-02-22 07:03] macke created |
projects:crazyflie:crtp [2017-04-01 21:29] theseankelly [Port allocation] |
====== Crazy RealTime Protocol ====== | ====== Crazy RealTime Protocol ====== | ||
The protocol used to communicate with the Crazyflie is called the Crazy RealTime Protocol, or CRTP in short. It's a simple protocol mainly designed to suit the radio chip used on the Crazyflie but the protocol can also be used on other physical links. | The protocol used to communicate with the Crazyflie is called the Crazy RealTime Protocol, or CRTP in short. It's a simple protocol mainly designed to suit the radio chip used on the Crazyflie but the protocol can also be used on other physical links. | ||
+ | This page and it's sub-pages describe the protocol itself, not the implementation of some of the more complex functions such as logging and parameters. | ||
===== Header ===== | ===== Header ===== | ||
Line 20: | Line 22: | ||
- | <code> | + | <ditaa> |
Line 28: | Line 30: | ||
- | </code> | + | </ditaa> |
* **CRTP Link** is responsible for transferring the packets between the Crazyflie and the host. It will typically handles packet size and error detection. | * **CRTP Link** is responsible for transferring the packets between the Crazyflie and the host. It will typically handles packet size and error detection. | ||
Line 38: | Line 40: | ||
^ **Port** | ^ **Port** | ||
====== Physical layers ====== | ====== Physical layers ====== | ||
Line 54: | Line 57: | ||
===== Serial port ===== | ===== Serial port ===== | ||
- | This is mostly for legacy support but has been used during development to log data at higher speeds. The support for using the serial port might be broken currently though. | + | The serial port is configured in 115200 8N1. CRTP packets are sent and received asynchronously |
+ | 7 | ||
+ | | Port | ||
+ | | DATA 0 | | ||
+ | | Cksum | | ||
- | ^ **Field** ^ **Byte** ^ | + | ^ **Field** ^ **Byte** ^ **Bit** ^ |
- | | Size | + | | ::: | |
- | | Data | + | | ::: | |
- | | CRC | + | | Size |
+ | | Data | ||
+ | | Cksum | ||
+ | ==== Example ==== | ||
+ | To send setpoints to the [[projects: | ||
+ | 0xaa 0xaa 0x30 0x0e 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3e | ||
+ | To ping Crazyflie: | ||
