projects:crazyflie:crtp [2013-02-22 07:21] macke |
projects:crazyflie:crtp [2013-04-02 15:40] arnaud [Serial port] |
Line 41: | Line 41: | ||
^ **Port** | ^ **Port** | ||
Line 56: | Line 56: | ||
===== Serial port ===== | ===== Serial port ===== | ||
- | This is mostly for legacy support but has been used during development to log data at higher speeds. The support for using the serial port might be broken currently though. | + | The serial port is configured in 115200 8N1. CRTP packets are sent and received asynchronously |
+ | 7 | ||
+ | | Port | ||
+ | | DATA 0 | | ||
+ | | Cksum | | ||
- | ^ **Field** ^ **Byte** ^ | ||
- | | Size | ||
- | | Data | ||
- | | CRC | | ||
+ | ^ **Field** ^ **Byte** ^ **Bit** ^ | ||
+ | | Size | ||
+ | | Data | ||
