projects:crazyflie:crtp [2013-04-02 15:38] arnaud [Serial port] |
projects:crazyflie:crtp [2013-04-02 15:41] arnaud [Layers] |
Line 22: | Line 22: | ||
- | <code> | + | <ditaa> |
Line 30: | Line 30: | ||
- | </code> | + | </ditaa> |
* **CRTP Link** is responsible for transferring the packets between the Crazyflie and the host. It will typically handles packet size and error detection. | * **CRTP Link** is responsible for transferring the packets between the Crazyflie and the host. It will typically handles packet size and error detection. | ||
Line 56: | Line 56: | ||
===== Serial port ===== | ===== Serial port ===== | ||
7 | 7 | ||
Line 70: | Line 72: | ||
- | | DATA 30 | | ||
| Cksum | | | Cksum | |
