projects:crazyflie:crtp [2013-04-02 15:38] arnaud [Serial port] |
projects:crazyflie:crtp [2015-07-15 16:31] 127.0.0.1 external edit |
Line 22: | Line 22: | ||
- | <code> | + | <ditaa> |
Line 30: | Line 30: | ||
- | </code> | + | </ditaa> |
* **CRTP Link** is responsible for transferring the packets between the Crazyflie and the host. It will typically handles packet size and error detection. | * **CRTP Link** is responsible for transferring the packets between the Crazyflie and the host. It will typically handles packet size and error detection. | ||
Line 56: | Line 56: | ||
===== Serial port ===== | ===== Serial port ===== | ||
7 | 7 | ||
Line 70: | Line 72: | ||
- | | DATA 30 | | ||
| Cksum | | | Cksum | | ||
Line 89: | Line 89: | ||
| Data | | Data | ||
+ | ==== Example ==== | ||
+ | To send setpoints to the [[projects: | ||
+ | 0xaa 0xaa 0x30 0x0e 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3e | ||
+ | To ping Crazyflie: | ||
