User Tools
Site Tools
projects:crazyflie:crtp
Differences
Link to this comparison view
Next revision
Previous revision
projects:crazyflie:crtp [2013-02-22 07:03]
macke created
projects:crazyflie:crtp [2017-04-01 21:29] (current)
theseankelly [Port allocation]
Line 1: Line 1:
 ====== Crazy RealTime Protocol ====== ====== Crazy RealTime Protocol ======
 The protocol used to communicate with the Crazyflie is called the Crazy RealTime Protocol, or CRTP in short. It's a simple protocol mainly designed to suit the radio chip used on the Crazyflie but the protocol can also be used on other physical links. The protocol used to communicate with the Crazyflie is called the Crazy RealTime Protocol, or CRTP in short. It's a simple protocol mainly designed to suit the radio chip used on the Crazyflie but the protocol can also be used on other physical links.
 +This page and it's sub-pages describe the protocol itself, not the implementation of some of the more complex functions such as logging and parameters.
 ===== Header ===== ===== Header =====
Line 20: Line 22:
 CRTP is implemented in 3 layers: CRTP is implemented in 3 layers:
-<code>+<ditaa>
    Application/ports   |    Application/ports   |
Line 28: Line 30:
        CRTP Link       |        CRTP Link       |
-</code>+</ditaa>
   * **CRTP Link** is responsible for transferring the packets between the Crazyflie and the host. It will typically handles packet size and error detection.   * **CRTP Link** is responsible for transferring the packets between the Crazyflie and the host. It will typically handles packet size and error detection.
Line 38: Line 40:
 Current port allocation: Current port allocation:
 ^  **Port**  ^   **Target**    **Used for**   ^ ^  **Port**  ^   **Target**    **Used for**   ^
-|          |   [[projects:crazyflie:firmware:console | Console ]]      | Read console text that is printed to the console on the Crazyflie using consoleprintf | +|          |   [[projects:crazyflie:crtp:console | Console ]]      | Read console text that is printed to the console on the Crazyflie using consoleprintf |
-|          |   [[projects:crazyflie:firmware:param | Parameters]]   | Get/set parameters from the Crazyflie. Parameters are defined using a macro in the Crazyflie source-code | +|          |   [[projects:crazyflie:crtp:param | Parameters]]   | Get/set parameters from the Crazyflie. Parameters are defined using a [[projects:crazyflie:firmware:param|macro in the Crazyflie source-code]]
-|          |   [[projects:crazyflie:firmware:commander |Commander]]    | Sending control set-points for the roll/pitch/yaw/thrust regulators | +|          |   [[projects:crazyflie:crtp:commander |Commander]]    | Sending control set-points for the roll/pitch/yaw/thrust regulators |
-|          |   [[projects:crazyflie:firmware:log#communication_protocol|Log]]    | Set up log blocks with variables that will be sent back to the Crazyflie at a specified period. Log variables are defined using a macro in the Crazyflie source-code |+|          |   [[projects:crazyflie:crtp:log#|Log]]    | Set up log blocks with variables that will be sent back to the Crazyflie at a specified period. Log variables are defined using a [[projects:crazyflie:firmware:log|macro in the Crazyflie source-code]] |
 +|          |   [[projects:crazyflie:crtp:setpointgeneric | Setpoint Generic]] | For sending generic, extensible setpoints |
 |   14         [[projects:crazyflie:pc_utils:debugdriver|Client-side debugging]]    | Debugging the UI and exists only in the Crazyflie Python API and not in the Crazyflie itself.  | |   14         [[projects:crazyflie:pc_utils:debugdriver|Client-side debugging]]    | Debugging the UI and exists only in the Crazyflie Python API and not in the Crazyflie itself.  |
-|   15         [[projects:crazyflie:firmware:linklayer |Link layer ]]   | Used to control and query the communication link |+|   15         [[projects:crazyflie:crtp:linklayer |Link layer ]]   | Used to control and query the communication link |
 ====== Physical layers ====== ====== Physical layers ======
Line 54: Line 57:
 ===== Serial port ===== ===== Serial port =====
-This is mostly for legacy support but has been used during development to log data at higher speedsThe support for using the serial port might be broken currently though.+The serial port is configured in 115200 8N1CRTP packets are sent and received asynchronously using the following packet format:
 <code> <code>
 +  7               0
 +|             0xAA              |
 +|             0xAA              |
 +|      Port      Res  | Chan. |
 +|         Packet length         |
 +|            DATA 0             |
 +|            Cksum              |
-|  0xAA  |  0xAA  | Header | Length | Data0  | Packet | CRC32  |+|  0xAA  |  0xAA  | Header | Length | Data0  | Packet | Cksum  |
 </code> </code>
-^ **Field** ^ **Byte** ^     **Description**     ^ +^ **Field** ^ **Byte** ^ **Bit** ^     **Description**     ^
-|   Start      0-1   | Start token for synchronization (0xAAAA) +|   Start      0-1   |   0-2   | Start token for synchronization (0xAAAA)
-|   Header  |        | The destination channel +|   Header  |        |   0-1   | The destination channel  |
-|    Size          | The size of the packet +|    :::    |        |   2-3   | Reserved for the link layer |
-|    Data      4-34  | The data in the packet | +|    :::    |        |   4-7   | The destination port  |
-|    CRC    |   35-36  The CRC16 of the packet |+|    Size          |         | Number of data byte
 +|    Data      4-..  |         | The data in the packet |
 +|   Cksum    4+size          | Checksum. Sum of all the bytes, excluding //Start//, modulo 256. |
 +==== Example ====
 +To send setpoints to the [[projects:crazyflie:crtp:commander|commander]] send:
 +<code>
 +0xaa 0xaa 0x30 0x0e 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3e
 +</code>
 +To ping Crazyflie:
 +<code>
 + ->   0xaa 0xaa 0xf0 0x01 0x01 0xf2     # Sent to the copter
 + <  0xaa 0xaa 0xf0 0x01 0x01 0xf2     # Received from the copter
 +</code>
projects/crazyflie/crtp.1361513027.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
