| Both sides previous revision Previous revision | |||
projects:crazyflie:crtp [2017-04-01 21:29] theseankelly [Port allocation] |
projects:crazyflie:crtp [2021-06-24 16:48] (current) kimberly |
| ====== Crazy RealTime Protocol ====== | ====== Crazy RealTime Protocol ====== | ||
| The protocol used to communicate with the Crazyflie is called the Crazy RealTime Protocol, or CRTP in short. It's a simple protocol mainly designed to suit the radio chip used on the Crazyflie but the protocol can also be used on other physical links. | The protocol used to communicate with the Crazyflie is called the Crazy RealTime Protocol, or CRTP in short. It's a simple protocol mainly designed to suit the radio chip used on the Crazyflie but the protocol can also be used on other physical links. | ||
