projects:crazyflie:devenv:index [2012-03-15 20:47] macke |
projects:crazyflie:devenv:index [2021-06-24 16:47] kimberly |
====== Development environment ====== | ====== Development environment ====== | ||
===== Software Tools ===== | ===== Software Tools ===== | ||
==== Software used ==== | ==== Software used ==== | ||
- | The following software | + | The following software |
- | * [[http://www.mentor.com/embedded-software/ | + | * [[https://launchpad.net/gcc-arm-embedded/+download| |
- | * [[http://http:// | + | GNU Tools for ARM Embedded Processors]] |
+ | * [[http:// | ||
These are available for both Windows and Linux. | These are available for both Windows and Linux. | ||
==== Setup on Fedora 16 ==== | ==== Setup on Fedora 16 ==== | ||
=== Installing === | === Installing === | ||
+ | In order to fix the permissions so it's possible to use the JTAG and USB Radio without being root do the following steps. | ||
+ | sudo usermod -a -G plugdev username | ||
+ | Note that you will need to logout and in again for the added group to take effect. | ||
+ | Find the JTAG vendor/ | ||
+ | Create a file named / | ||
+ | SUBSYSTEM==" | ||
- | ==== Setup on Ubuntu | + | Create a file named / |
+ | ==== Setup on Ubuntu | ||
+ | wget https:// | ||
+ | mkdir ~/bin | ||
+ | And then also add the binaries to your path: | ||
+ | echo -e " | ||
+ | source ~/.bashrc | ||
==== Setup on Windows ==== | ==== Setup on Windows ==== | ||
+ | TBD | ||
+ | ==== Setup on Mac OS X ==== | ||
+ | Development environment setup is relatively easy on Mac OS X. | ||
+ | [[http:// | ||
Line 21: | Line 68: | ||
The Crazyflie project is based on a Makefile. A couple of target are useful: | The Crazyflie project is based on a Makefile. A couple of target are useful: | ||
- | crazyflie$ make # Make copter firmware | + | crazyflie-fimrware$ make # Make copter firmware |
- | crazyflie$ make V=1 # Make copter firmware and shows the full compilation commands | + | crazyflie-fimrware$ make V=1 # Make copter firmware and shows the full compilation commands |
- | crazyflie$ make CLOAD=1 # make copter firmware to be used with the bootloader | + | crazyflie-fimrware$ make CLOAD=1 # Make copter firmware to be used with the bootloader |
- | crazyflie$ make flash # Flash firmware using openOCD and the jtagKey | + | crazyflie-fimrware$ |
- | crazyflie$ make reset # Reset the copter using openOCD | + | crazyflie-fimrware$ make cload # Flash the firmware using the radio bootloader |
- | crazyflie$ make openocd # Launch openOCD and connect it to the copter (can then be used via the telnet interface and/or GDB) | + | crazyflie-fimrware$ make flash # Flash firmware using openOCD and the jtagKey |
+ | crazyflie-fimrware$ make reset # Reset the copter using openOCD | ||
A couple of variables can be set on the command line or shell environment to configure the build process: | A couple of variables can be set on the command line or shell environment to configure the build process: | ||
^ Variable ^ Default value ^ Usage ^ | ^ Variable ^ Default value ^ Usage ^ | ||
- | | CLOAD | | + | | CLOAD | |
- | | DEBUG | | + | | DEBUG | |
| CROSS_COMPILE | | | CROSS_COMPILE | | ||
| OPENOCD_INTERFACE | | | OPENOCD_INTERFACE | | ||
| V | 0 | Verbose mode. If V=1 the compilers command lines will be displayed. If V=0 only the tool type and target file are displayed. | | | V | 0 | Verbose mode. If V=1 the compilers command lines will be displayed. If V=0 only the tool type and target file are displayed. | | ||
+ | | PYTHON2 | python | ||
+ | | USE_ESKYLINK| | ||
+ | It is possible to create a file // | ||
- | It must be noted that the openOCD targets do not make the copter code, hence the compilation must be called first with '' | + | The openOCD targets do not make the copter code, hence the compilation must be called first with '' |
It is possible to flash with openOCD/ | It is possible to flash with openOCD/ | ||
Line 46: | Line 99: | ||
The copter can be loaded with a radio bootloader contained in the crazyloader folder. The dev environment is very similar to the copter one: | The copter can be loaded with a radio bootloader contained in the crazyloader folder. The dev environment is very similar to the copter one: | ||
- | crazyloader$ make # Make the bootoader | + | crazyflie-bootloader$ make # Make the bootoader |
- | crazyloader$ make flash # Flash the bootloader with openOCD | + | crazyflie-bootloader$ make flash # Flash the bootloader with openOCD |
