crazyflie$ make # Make copter firmware crazyflie$ make V=1 # Make copter firmware and shows the full compilation commands crazyflie$ make CLOAD=1 # make copter firmware to be used with the bootloader crazyflie$ make flash # Flash firmware using openOCD and the jtagKey crazyflie$ make reset # Reset the copter using openOCD crazyflie$ make openocd # Launch openOCD and connect it to the copter (can then be used via the telnet interface and/or GDB)
It must be noted that the openOCD targets do not make the copter code, hence the compilation must be called first with make and then make flash can be called.
