User Tools
Site Tools
projects:crazyflie:devenv:index
Differences
Link to this comparison view
Next revision
Previous revision
projects:crazyflie:devenv:index [2012-03-15 20:49]
macke
projects:crazyflie:devenv:index [2014-12-16 00:11]
chad Added a Setup on Mac OS X section with a link to a post about the Mac OS X dev environment.
Line 1: Line 1:
-====== Development environment ======
-===== Software Tools =====
-==== Software used ====
-The following software is in the Crazyflie development environment toolchain:
-  * [[http://www.mentor.com/embedded-software/sourcery-tools/sourcery-codebench/editions/lite-edition/|Sourcery CodeBench (formally known as Sourcery G++) Lite]]
-  * [[http://http://openocd.sourceforge.net/|openOCD]]
-These are available for both Windows and Linux.
-==== Setup on Fedora 16 ====
-=== Installing ===
-In order to fix the permissions so it's possible to use the JTAG and USB Radio without being root do the following steps.
-<code>
-sudo usermod -a -G plugdev username
-</code>
-Note that you will need to logout and in again for the added group to take effect.
-Find the JTAG vendor/product ID by running lsusb.
-Create a file named /etc/udev/rules.d/99-jtagkey.rules and add the following:
-<code>
-SUBSYSTEM=="usb", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="cff8", MODE="0664", GROUP="plugdev"
-</code>
-Create a file named /etc/udev/rules.d/99-crazyradio.rules and add the following:
-<code>
-SUBSYSTEM=="usb", ATTRS{idVendor}=="1915", ATTRS{idProduct}=="7777", MODE="0664", GROUP="plugdev"
-</code>
-==== Setup on Ubuntu 10.04 LTS / 11.10 ====
-==== Setup on Windows ====
-===== Compiling the copter code =====
-The Crazyflie project is based on a Makefile. A couple of target are useful:
-<code bash>
-crazyflie$ make         # Make copter firmware
-crazyflie$ make V=1     # Make copter firmware and shows the full compilation commands
-crazyflie$ make CLOAD=1 # make copter firmware to be used with the bootloader
-crazyflie$ make flash   # Flash firmware using openOCD and the jtagKey
-crazyflie$ make reset   # Reset the copter using openOCD
-crazyflie$ make openocd # Launch openOCD and connect it to the copter (can then be used via the telnet interface and/or GDB)
-</code>
-A couple of variables can be set on the command line or shell environment to configure the build process:
-^  Variable ^  Default value  ^ Usage ^
-|  CLOAD |      0        | If at 1 the firmware is liked to be used with the bootloader.            |
-|  DEBUG |      1        | If at 1 the firmware will be build without optimization and with debug symbol (the firmware is ~70K in debug mode and ~40K optimized). |
-|  CROSS_COMPILE |   arm-none-eabi-   | Prefix of the cross compilation toolchain to use. Any bare arm GCC should do. The default value is good for the CodeSourcery toolchain. |
-|  OPENOCD_INTERFACE |   interface/jtagkey.cfg   | JTAG interface configuration file to use with openOCD. Default is for the Amontec JtagKEY. |
-|  V |      0        | Verbose mode. If V=1 the compilers command lines will be displayed. If V=0 only the tool type and target file are displayed. |
-It must be noted that the openOCD targets do not make the copter code, hence the compilation must be called first with ''make'' and then ''make flash'' can be called.
-It is possible to flash with openOCD/jtag a bootloader version of the copter as long as the bootloader is present at the beginning of the flash. However this could interfere with GDB.
-It is also possible to work with the copter code from within Eclipse.
-===== Compiling and flashing the bootloader =====
-The copter can be loaded with a radio bootloader contained in the crazyloader folder. The dev environment is very similar to the copter one:
-<code bash>
-crazyloader$ make       # Make the bootoader
-crazyloader$ make flash # Flash the bootloader with openOCD
-</code>
projects/crazyflie/devenv/index.txt · Last modified: 2021-06-24 16:47 by kimberly
