projects:crazyflie:devenv:index
Development environment
Software Tools
Software used
Setup on Fedora 16
Installing
Setup on Ubuntu 10.04 LTS / 11.10
Setup on Windows
Compiling the copter code
crazyflie$ make         # Make copter firmware
crazyflie$ make V=1     # Make copter firmware and shows the full compilation commands
crazyflie$ make CLOAD=1 # make copter firmware to be used with the bootloader
crazyflie$ make flash   # Flash firmware using openOCD and the jtagKey
crazyflie$ make reset   # Reset the copter using openOCD
crazyflie$ make openocd # Launch openOCD and connect it to the copter (can then be used via the telnet interface and/or GDB)
Variable Default value Usage
CLOAD 0 If at 1 the firmware is liked to be used with the bootloader.
DEBUG 1 If at 1 the firmware will be build without optimization and with debug symbol (the firmware is ~70K in debug mode and ~40K optimized).
CROSS_COMPILE arm-none-eabi- Prefix of the cross compilation toolchain to use. Any bare arm GCC should do. The default value is good for the CodeSourcery toolchain.
OPENOCD_INTERFACE interface/jtagkey.cfg JTAG interface configuration file to use with openOCD. Default is for the Amontec JtagKEY.
V 0 Verbose mode. If V=1 the compilers command lines will be displayed. If V=0 only the tool type and target file are displayed.
It must be noted that the openOCD targets do not make the copter code, hence the compilation must be called first with make and then make flash can be called.
Compiling and flashing the bootloader
crazyloader$ make       # Make the bootoader
crazyloader$ make flash # Flash the bootloader with openOCD
projects/crazyflie/devenv/index.1331840984.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
