projects:crazyflie:devenv:index [2013-06-07 09:50] macke |
projects:crazyflie:devenv:index [2015-07-15 16:31] 127.0.0.1 external edit |
Line 54: | Line 54: | ||
TBD | TBD | ||
+ | ==== Setup on Mac OS X ==== | ||
+ | Development environment setup is relatively easy on Mac OS X. | ||
+ | [[http:// | ||
Line 60: | Line 67: | ||
crazyflie-fimrware$ make # Make copter firmware | crazyflie-fimrware$ make # Make copter firmware | ||
crazyflie-fimrware$ make V=1 # Make copter firmware and shows the full compilation commands | crazyflie-fimrware$ make V=1 # Make copter firmware and shows the full compilation commands | ||
- | crazyflie-fimrware$ make CLOAD=1 # make copter firmware to be used with the bootloader | + | crazyflie-fimrware$ make CLOAD=1 # Make copter firmware to be used with the bootloader |
+ | crazyflie-fimrware$ make clean && | ||
crazyflie-fimrware$ make cload # Flash the firmware using the radio bootloader | crazyflie-fimrware$ make cload # Flash the firmware using the radio bootloader | ||
crazyflie-fimrware$ make flash # Flash firmware using openOCD and the jtagKey | crazyflie-fimrware$ make flash # Flash firmware using openOCD and the jtagKey | ||
Line 75: | Line 83: | ||
| V | 0 | Verbose mode. If V=1 the compilers command lines will be displayed. If V=0 only the tool type and target file are displayed. | | | V | 0 | Verbose mode. If V=1 the compilers command lines will be displayed. If V=0 only the tool type and target file are displayed. | | ||
| PYTHON2 | python | | PYTHON2 | python | ||
+ | | USE_ESKYLINK| | ||
It is possible to create a file // | It is possible to create a file // |
