The following software are used by the Crazyflie development environment toolchain:
SUBSYSTEM=="usb", ATTRS{idVendor}=="1915", ATTRS{idProduct}=="0101", MODE="0664", GROUP="plugdev"
Most of the software that you will need is now available from the repositories so just run the following command to install it:
sudo apt-get -y install mercurial python2.7 python-usb python-pygame python-qt4 qt4-designer openocd build-essential
Run the following to download, unpack and copy the ARM Embedded toolchain:
wget https://launchpad.net/gcc-arm-embedded/4.7/4.7-2013-q1-update/+download/gcc-arm-none-eabi-4_7-2013q1-20130313-linux.tar.bz2 tar xjf gcc-arm-none-eabi-4_7-2013q1-20130313-linux.tar.bz2 mkdir ~/bin mv gcc-arm-none-eabi-4_7-2013q1 ~/bin/gcc-arm-none-eabi
And then also add the binaries to your path: In order for the build system to find the toolchain when building the firmware it has to be added to the path:
echo -e "\nPATH=\$PATH:$HOME/bin/gcc-arm-none-eabi/bin" >> ~/.bashrc source ~/.bashrc
TBD
crazyflie-fimrware$ make # Make copter firmware crazyflie-fimrware$ make V=1 # Make copter firmware and shows the full compilation commands crazyflie-fimrware$ make CLOAD=1 # make copter firmware to be used with the bootloader crazyflie-fimrware$ make cload # Flash the firmware using the radio bootloader crazyflie-fimrware$ make flash # Flash firmware using openOCD and the jtagKey crazyflie-fimrware$ make reset # Reset the copter using openOCD crazyflie-fimrware$ make openocd # Launch openOCD and connect it to the copter (can then be used via the telnet interface and/or GDB)
| CLOAD | 1 | If at 1 the firmware is liked to be used with the bootloader. |
| DEBUG | 0 | If at 1 the firmware will be build without optimization and with debug symbol (the firmware is ~70K in debug mode and ~40K optimized). |
crazyflie-bootloader$ make # Make the bootoader crazyflie-bootloader$ make flash # Flash the bootloader with openOCD
