projects:crazyflie:firmware:comm_protocol [2012-11-11 18:14] arnaud [Overview] |
projects:crazyflie:firmware:comm_protocol [2014-05-09 04:21] fred [Logging] fixed tiny but significant typo in hex string that cost me an hour of debugging |
Line 21: | Line 21: | ||
^ **Link** | ^ **Link** | ||
- | ^ | + | ^ **Port** |
- | | [[comm_protocol# | + | | |
- | | 1 | | + | | 2 |
- | | [[comm_protocol#commander|3]] | | + | | |
+ | | 15 | ||
====== Communication ====== | ====== Communication ====== | ||
Line 46: | Line 47: | ||
| DATA 30 | | | DATA 30 | | ||
- | | 0xAA | 0xAA | Header | Length | Data0 | Packet | CRC32 | | ||
Line 64: | Line 61: | ||
Line 70: | Line 67: | ||
==== Serial port ==== | ==== Serial port ==== | ||
7 | 7 | ||
Line 77: | Line 76: | ||
- | | R | | + | | |
Line 87: | Line 86: | ||
Line 97: | Line 96: | ||
^ **Field** ^ **Byte** ^ **Bit** ^ | ^ **Field** ^ **Byte** ^ **Bit** ^ | ||
- | | Size | + | | Size |
- | | Data | + | | Data |
- | | | + | | Cksum | |
- | ===== Ports ===== | + | === Examples |
- | + | To send setpoints to the [[projects: | |
- | ==== Console ==== | + | < |
- | This port is used as a one-way text console. Printouts using printf will be sent on this port and can be read by a receiver if connected. | + | 0xaa 0xaa 0x30 0x0e 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3e |
+ | To ping Crazyflie: | ||
- | +---+---+---+---+---+---+---+---+ | + | <- 0xaa 0xaa 0xf0 0x01 0x01 0xf2 # Received from the copter |
- | | CHAR 0 | | + | |
- | | CHAR 30 | | + | |
- | | 0xAA | 0xAA | Header | Length | Data0 | | Data30 | | + | |
- | + | ===== Ports ===== | |
- | The contents of the buffer on the copter side is sent if any of the following is fulfulled: | + | |
- | * The output buffer (of 31 bytes) is full | + | |
- | * A " | + | |
- | * A flush command as been issued | + | |
==== Logging ==== | ==== Logging ==== | ||
Line 138: | Line 124: | ||
Line 144: | Line 130: | ||
Line 180: | Line 167: | ||
- | with ID omitted | + | |
+ | [optional] | ||
+ | (or any higher) | ||
Line 197: | Line 190: | ||
+ | | Reset log | ||
^ **Byte** | ^ **Byte** | ||
Line 221: | Line 217: | ||
Line 232: | Line 229: | ||
Line 242: | Line 239: | ||
7 | 7 | ||
Line 251: | Line 249: | ||
7 | 7 | ||
+ | | 0xff | | ||
Line 267: | Line 268: | ||
- | | 0x00 | + | | |
- | | 0x01 | + | | |
- | | 0xFF | + | | |
[DONE] | [DONE] | ||
Line 301: | Line 303: | ||
+ | ^ **Byte** | ||
The parameters system aims at making accessible all the gettable and settable parameters of the copter. In the copter a table of parameters is hold and can be retrieved. In this table every parameter name is associated with an ID and a group name. Three ID are used to acces the TOC and the paramareters: | The parameters system aims at making accessible all the gettable and settable parameters of the copter. In the copter a table of parameters is hold and can be retrieved. In this table every parameter name is associated with an ID and a group name. Three ID are used to acces the TOC and the paramareters: |
