Implemented link drivers:
Link | |
UART | Uart link, mainly used in early development |
USB | To be implemented USB link. |
radio | 2.4 GHz NordicSemi Radio link |
Current port allocation:
Field | Byte | Bit | Description |
Header | 0 | 0-1 | The destination channel |
0 | 2-3 | Reserved for transport layer | |
0 | 4-7 | The destination port | |
Data | 1-31 | The data in the packet |
Start | 0-1 | 0-2 | Start token for synchronization (0xAAAA) |
Header | 2 | 0-2 | The destination channel |
2 | 3-6 | The destination port | |
2 | 7 | Resend flag. If R=1 the last packet needs to be resent | |
Size | 3 | The size of the packet | |
Data | 4-34 | The data in the packet | |
CRC | 35-36 | The CRC16 of the packet |
Port | Channel | Function |
5 | 0 | Table of content access |
5 | 1 | Log settings access |
5 | 2 | Log data access |
Request for | Byte | Description |
TOC item | 0 | 0x00 to identify the command |
1 | The index of the TOC item to request. This is optional, if the index is omitted the first item of the TOC will be returned | |
TOC CRC and count | 0 | Request the TOC CRC and item count |
Reply for | Byte | Description |
1 | The ID of the next variable to fetch. If ID == 0xFF no more items are available. | |
2 | Variable ID | |
3 | Type (ref to variable type?) | |
4-n | Null terminated string containing group name | |
n-m | Null terminated string containing variable name | |
TOC CRC and count | 0 | 0x01 to identify the command |
1 | Number of total variables in TOC | |
2-5 | CRC32 value of the TOC (of what exacly? group/names?) |
Computer Crazyflie -------- --------- Get TOC CRC32 ---> <--- TOC CRC32 [Compare CRC]
Computer Crazyflie -------- --------- Request for TOC item ---> with ID omitted <--- First TOC element (including ID of next element) Request for TOC item ---> <--- Requested TOC element (including ID of next element) .... .... Request for TOC item ---> <--- Requested TOC element (no more items, return next index 0xFF) [Fetch complete]
Adding a new log | 0 | 0x00 for identifying the command to add a logging block |
1 | Desired block id | |
2 | Period in 10th of ms | |
3-31 | Variables to log | |
Append to log | 0 | 0x01 for identifying the command to append logging variables to an existing block |
1 | Block ID | |
2-31 | Variables to log | |
Delete a log | 0 | 0x02 to identify the command for delete an existing block |
1 | Block ID | |
Enable a log | 0 | 0x03 to identify the command for enabling logging data from an existing block |
1 | Block ID | |
Disable a log | 0 | 0x04 to identify the command for disablling logging data from an existing block |
1 | Block ID |
0 | The command byte that was sent |
1 | The ID of the log block that the command operated on |
2 | Return status for the command. If != 0 see list of return codes |
Log Type | Description |
1 | uint8_t |
2 | uint16_t |
3 | uint32_t |
4 | int8_t |
5 | int16_t |
6 | int32_t |
7 | float32 |
8 | float16 |
Storage Type | Description |
0 | Variable in TOC |
1 | Memory address pointing to uint8_t |
2 | Memory address pointing to uint16_t |
3 | Memory address pointing to uint32_t |
4 | Memory address pointing to int8_t |
5 | Memory address pointing to int16_t |
6 | Memory address pointing to int32_t |
7 | Memory address pointing to float32 |
Error | Description |
0x00 | No error |
0x01 | Block not found |
0x02 | Block already created, needs delete |
0xFF | Generic error |
Computer Crazyflie -------- --------- Add log packet ---> <--- Log packet added ok [DONE] Packet structure: Computer -> CF : 0x[5,1] 0x00 0x01 0x0A 0x02 0x55 CF -> Computer : 0x[5,1] 0x00 0x55 0x00
Computer Crazyflie -------- --------- Delete log packet ---> <--- Log packet deleted ok [DONE] Packet structure: Computer -> CF : 0x[5,1] 0x02 0x55 CF -> Computer : 0x[5,1] 0x02 0x55 0x00
Port | Function |
(0,9,0) | TOC access |
(0,9,1) | Parameter read |
(0,9,2) | Parameter write |
Message ID | Meaning in upstream packets | Meaning in downstream packets |
0 | Reset TOC pointer | Last TOC element |
1 | Get next TOC element | TOC element |
3 | Get TOC CRC32 | TOC CRC32 |
Bytes 1 1 1 Null terminated strings +---+------------+------+----------+--------------+ | 0 | | | | | +---+ Param ID | Type | Group | Name | | 1 | | | | | +---+------------+------+---+------+--------------+ | 3 | Num. Param | CRC32 | +---+------------+----------+ Bytes 1 1 4
3:15:0 | Echo (profiling) |
3:15:1 | Source (profiling) |
3:15:2 | Sink (profiling) |
3:15:3 | NULL packet |
