projects:crazyflie:firmware:comm_protocol [2013-08-23 19:54] ledvinap |
projects:crazyflie:firmware:comm_protocol [2015-07-15 16:31] 127.0.0.1 external edit |
Line 124: | Line 124: | ||
Line 130: | Line 130: | ||
- | | TOC CRC and count | 0 | 0x01 Request the TOC CRC and item count | | + | | TOC CRC and count | 0 | 0x01 (CMD_GET_INFO) |
Line 166: | Line 167: | ||
- | with ID omitted | + | |
+ | [optional] | ||
+ | (or any higher) | ||
Line 183: | Line 190: | ||
+ | | Reset log | ||
^ **Byte** | ^ **Byte** | ||
Line 207: | Line 217: | ||
Line 218: | Line 229: | ||
Line 228: | Line 239: | ||
7 | 7 | ||
Line 237: | Line 249: | ||
7 | 7 | ||
+ | | 0xff | | ||
Line 253: | Line 268: | ||
- | | 0x00 | + | | |
- | | 0x01 | + | | |
- | | 0xFF | + | | |
[DONE] | [DONE] | ||
Line 287: | Line 303: | ||
+ | ^ **Byte** | ||
Line 329: | Line 352: | ||
+ | The CRC32 is a hash of the copter TOC. This is aimed at implementing caching of the TOC in the PC Utils to avoid fetching the full TOC each time the copter is connected. | ||
+ | === Parameter read (Port 2 channel 1) and parameter write (Port 2 channel 2)=== | ||
- | The CRC32 is a hash of the copter TOC. This is aim at implementing caching | + | The following messages are sent from the client to the Crazyflie: |
+ | ^ **Request for** | ||
+ | | Parameter read | | ||
+ | | Parameter write | ||
- | === Parameter read === | + | The following messages are sent from the Crazyflie to the client: |
- | **TODO** | + | ^ |
- | === Parameter write === | + | | Parameter read & write |
- | **TODO** | + | | ::: |
