projects:crazyflie:hardware:explained [2012-12-03 16:24] tobias [Sensors] |
projects:crazyflie:hardware:explained [2013-01-12 15:54] tobias [Specification] |
- | ====== Crazyflie KIT electonics | + | ====== Crazyflie KIT electronics |
This section is here to explain all high level electronics used in the Crazyflie. | This section is here to explain all high level electronics used in the Crazyflie. | ||
Line 54: | Line 54: | ||
===== Sensors ===== | ===== Sensors ===== | ||
- | As for sensors we run a " | + | As for sensors we run a " |
+ | With a 6-axis system it is not possible to remove the yaw drift and for an autonomous | ||
+ | It is also possible to manually solder-mount a MS5611 pressure sensor afterwards if that is of interest. This could make it possible add an altitude-hold functionality. No SW support now though. | ||
===== Expansion header ===== | ===== Expansion header ===== | ||
+ | The expansion header is located on the left side of the Crazyflie. It is a 10x2 pin 1.27mm (0.05" | ||
+ | The header is divided into two parts. The JTAG part, pin 1 to 10, and the buss/power part, pin 11 to 20. The UART RX/TX is located on the JTAG part because on many FTDI based JTAGs it is possible to use one channel for serial communication which can be very handy when debugging. | ||
+ | Header pin description | ||
+ | ^^ Pin nr ^^ Name ^^ Description ^^ | ||
+ | || 1 || VCC || Digital supply voltage || | ||
+ | || 2 || TMS || Test Mode Select || | ||
+ | || 3 || EXT_I2C_SCL/ | ||
+ | || 4 || TCK || Test Clock || | ||
+ | || 5 || EXT_I2C_SDA/ | ||
+ | || 6 || TDO || Test Data Out || | ||
+ | || 7 || N/A || Could be used for keying || | ||
+ | || 8 || TDI || Test Data In || | ||
+ | || 9 || DGND || Digital ground || | ||
+ | || 10 || SNRST || System reset || | ||
+ | || 11 || EXT_SPI_CS/ | ||
+ | || 12 || EXT_SPI_MOSI/ | ||
+ | || 13 || EXT_SPI_SCK/ | ||
+ | || 14 || EXT_SPI_MISO/ | ||
+ | || 15 || VCC || Digital supply voltage || | ||
+ | || 16 || VCOM || Battery/USB voltage || | ||
+ | || 17 || DGND || Digital ground || | ||
+ | || 18 || DGND || Digital ground || | ||
+ | || 19 || AGND || Analogue ground|| | ||
+ | || 20 || VCCA || Analogue supply || | ||
===== 2.4GHz radio ===== | ===== 2.4GHz radio ===== | ||
+ | The motor driver, as we use brushed motors, is a simple pull down mosfet as shown in the schematics. There is also a free-wheel diode to take the Back-EMF spikes generated by the motor during PWM-ing. | ||
+ | The mosfet we choose is the PMV31XN in a SOT-23 package. It can handle a lot of power and should be good for at least 3A each. The most important property of the mosfet though might be the on resistance (Rdson) since it effects the amount of power the motors can make use of. We measured the PMV31XN Rdson at 2.8V G-D voltage and 0.8A D-S current to be ~40 mOhm. | ||
+ | **Electrical** | ||
+ | **Mechanical** | ||
+ | || Weight || 1.6g approx.|| | ||
