| Item | Specification | ||
Specification:
As for sensors we run a “6-axis” system using the MPU-6050 which contains a 3-axis gyroscope and an 3-axis accelerometer. This is enough to “attitude” stabilize the Crazyflie making it self levelling. However with a 6-axis system it is not possible to remove the yaw drift and for an autonomus system this would be important. Therefore it is possible to add an magnetometer (HMC58
