projects:crazyflie:hardware:explained [2014-10-18 03:28] chad [Expansion header] Minor spelling and punctuation changes. |
projects:crazyflie:hardware:explained [2021-06-24 16:49] (current) kimberly |
| ====== Crazyflie KIT electronics explained ====== | ====== Crazyflie KIT electronics explained ====== | ||
| This section is here to explain all high level electronics used in the Crazyflie. | This section is here to explain all high level electronics used in the Crazyflie. | ||
| Line 35: | Line 38: | ||
| Specification: | Specification: | ||
| - | || Model || Voltage (V) || Capacity (mAh) || Thickness (±0.2) || Width (±0.5) || Height (±0.5) || Weight (g) || Charge Rate || Continues | + | || Model || Voltage (V) || Capacity (mAh) || Thickness (±0.2) || Width (±0.5) || Height (±0.5) || Weight (g) || Charge Rate || Continuous |
| || 671723HS25C || 3.7 || 170 || 6.9 ||17 || 23 || 3.9 || 1C-5C || 25C (≥ 80%) || 50C || | || 671723HS25C || 3.7 || 170 || 6.9 ||17 || 23 || 3.9 || 1C-5C || 25C (≥ 80%) || 50C || | ||
