The battery we use is of the type LiPo (Lithium-Polymer). They are currently the most popular battery type for R/C use. The LiPo is however not the safest chemistry and should be handled with care. Failing to do so could make it catch on fire. It is also sensitive to under/over charge, to high discharge/shortage, heat and more. What it is good at however compensates for all these shortcomings as it has among the best power to weight ratios and discharge currents.
| Item | Specification | ||
| Short release condition | Cut off load | ||
Specification:
| Model | Voltage (V) | Capacity (mAh) | Thickness (±0.2) | Width (±0.5) | Height (±0.5) | Weight (g) | Charge Rate | Continues Discharge Rate | Burst (≤5S) | ||||||||||
The Crazyflie control board utilizes the separate power plane technique using a 4 layer board. It has proven to work pretty well and we have low ripple currents. However it is not perfect and at some Radio channels we can notice that the motor PWM sometimes is interfering with the Radio.
There are a number of supplies and grounds
| Supply | Range (V) | Description | |||
| +BATT | 3.0 - 4.2 | Battery supply voltage | |||
| VCOM | 3.0 - 5.5 | Supply after power management chip. Can be +BATT or USB voltage | |||
| VCC | 2.8 or 3.3 | Digital supply voltage. Input is the VCOM supply | |||
| VCCA | 2.8 | Analog supply voltage, which is filtered. Input is the VCOM supply | |||
| GND | 0 | The ground shared by the motor drivers and the battery | |||
| DGND | 0 | Digital ground. Connected to GND in a start-point fashion. | |||
| AGND | 0 | Analog ground. Connected to GND in a start-point fashion. |
The analog and digital supply uses the TPS79301 adjustable voltage regulator. It is a ultra-low noise 200 mA capable LDO voltage regulator. We choose to use the adjustable variant for both supplies to have maximum tune-ability. This way one can set the output voltage just by changing a couple of resistors. It has also enabled us to make the digital supply switch from 2.8 V to 3.3 V when the micro-USB cable is connected so we can comply the the USB standard.
The expansion header is located on the left side of the Crazyflie. It is a 10×2 pin 1.27mm (0.05“) pitch through-hole footprint which comes unmounted. The idea with the through-hole is that it makes it possible to mount expansion boards on either, or both, sides. It would even be possible to stack several on top of each other.
Header pin description
| Pin nr | Name | Description | |||
| 1 | VCC | Digital supply voltage | |||
| 2 | TMS | Test Mode Select | |||
| 3 | EXT_I2C_SCL/TX | I2C clock or UART TX | |||
| 4 | TCK | Test Clock | |||
| 5 | EXT_I2C_SDA/RX | I2C data or UART RX | |||
| 6 | TDO | Test Data Out | |||
| 7 | N/A | Could be used for keying | |||
| 8 | TDI | Test Data In | |||
| 9 | DGND | Digital ground | |||
| 10 | SNRST | System reset | |||
| 11 | EXT_SPI_CS/AIN4 | SPI chip select or analogue in 4 | |||
| 12 | EXT_SPI_MOSI/AIN7 | SPI Master Out Slave In chip or analogue in 7 | |||
| 13 | EXT_SPI_SCK/AIN5 | SPI clock or analogue in 5 | |||
| 14 | EXT_SPI_MISO/AIN6 | SPI Master In Slave Out chip or analogue in 6 | |||
| 15 | VCC | Digital supply voltage | |||
| 16 | VCOM | Battery/USB voltage | |||
| 17 | DGND | Digital ground | |||
| 18 | DGND | Digital ground | |||
| 19 | AGND | Analogue ground | |||
| 20 | VCCA | Analogue supply |
The motor driver, as we use brushed motors, is a simple pull down mosfet as shown in the schematics. There is also a free-wheel diode to take the Back-EMF spikes generated by the motor during PWM-ing.
The mosfet we choose is the PMV31XN in a SOT-23 package. It can handle a lot of power and should be good for at least 3A each. The most important property of the mosfet though might be the on resistance (Rdson) since it effects the amount of power the motors can make use of. We measured the PMV31XN Rdson at 2.8V G-D voltage and 0.8A D-S current to be ~40 mOhm.
We use a coreless brushed DC motor 6x15mm.
Electrical
| Description | Value | ||
| Rated voltage | 4.2 V Max | ||
| Nominal voltage | 3.7 V | ||
| No load speed | 45000 ±15% RPM | ||
| No load current | 80 mA Max | ||
| Starting voltage | 0.8 V Max | ||
| Rated load speed | 21000 ±15% RPM | ||
| Rated load current | 810 mA Max | ||
| Resistance | 2.3 ±20% Ω |
Mechanical
| Shaft diameter | 0.8 mm | ||
| Motor diameter | 6 ± 0.05 mm | ||
| Motor length | 15 mm | ||
| Weight | 1.7 g approx. |
