User Tools
Site Tools
projects:crazyflie:hardware:explained
Differences
Link to this comparison view
Next revision
Previous revision
projects:crazyflie:hardware:explained [2014-10-18 03:28]
chad [Expansion header] Minor spelling and punctuation changes.
projects:crazyflie:hardware:explained [2021-06-24 16:49] (current)
Line 1: Line 1:
 +</WRAP>
 ====== Crazyflie KIT electronics explained ====== ====== Crazyflie KIT electronics explained ======
 This section is here to explain all high level electronics used in the Crazyflie. This section is here to explain all high level electronics used in the Crazyflie.
Line 35: Line 38:
 Specification: Specification:
-|| Model || Voltage (V) || Capacity (mAh) || Thickness (±0.2) || Width (±0.5) || Height (±0.5) || Weight (g) || Charge Rate || Continues Discharge Rate || Burst (≤5S)||+|| Model || Voltage (V) || Capacity (mAh) || Thickness (±0.2) || Width (±0.5) || Height (±0.5) || Weight (g) || Charge Rate || Continuous Discharge Rate || Burst (≤5S)||
 || 671723HS25C || 3.7 || 170 || 6.9 ||17 || 23 || 3.9 || 1C-5C || 25C (≥ 80%) || 50C || || 671723HS25C || 3.7 || 170 || 6.9 ||17 || 23 || 3.9 || 1C-5C || 25C (≥ 80%) || 50C ||
 {{:projects:crazyflie:hardware:fullriver_671723hs25c_wiki.png?500|}} {{:projects:crazyflie:hardware:fullriver_671723hs25c_wiki.png?500|}}
projects/crazyflie/hardware/explained.1413595724.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
