User Tools
Site Tools
projects:crazyflie:mechanics:assembly
Differences
Link to this comparison view
Next revision
Previous revision
projects:crazyflie:mechanics:assembly [2013-05-06 22:39]
tobias [What do you need to do]
projects:crazyflie:mechanics:assembly [2013-06-01 23:16]
foosel [What do you need to do]
Line 14: Line 14:
   * Scissors    * Scissors
   * Tweezers and a clamp or third-hand can come in handy   * Tweezers and a clamp or third-hand can come in handy
 +====== Check the electronics ======
 +Before you go ahead and assemble the Crazyflie check the Crazyflie control board and the Crazyradio electronics:
 +{{:projects:crazyflie:mechanics:test_ccb.png?direct&200 |}}
 +1. Attach a powered micro-USB cable to the Crazyflie control board. It should power up and blink 5 times with the green LED. After that the green LED should be fully on and the red LED should blink.
 +2. Attach the Crazyradio to a computer and follow the [[http://wiki.bitcraze.se/projects:crazyflie:pc_utils:install|installation instructions]]. When the Crazyradio is found and enumerated the red and green led will turn off. This is a good sign.
 +3. When the cf-client is installed and the Crazyradio is working it should be possible to connect to the Crazyflie using the connect button in cf-client. Test that you can connect. It is also a good time to update the firmware now using the [[http://wiki.bitcraze.se/projects:crazyflie:pc_utils:qt_ui#bootloader|bootloader]]. Latest stable binaries can be found [[http://wiki.bitcraze.se/projects:crazyflie:binaries:index| here]].
 +When all these tests passed go ahead and start the assembly. If they did not pass visit the forum and open a support thread if you can't already find one describing the problem.
 ====== What do you need to do ====== ====== What do you need to do ======
Line 25: Line 37:
 {{:projects:crazyflie:mechanics:twist_motor_wires_done.png?direct&300}} {{:projects:crazyflie:mechanics:twist_motor_wires_done.png?direct&300}}
-3. Thread the twisted motor wires through the motor mount arm section. can be a bit tricky so have patience.+3. Thread the twisted motor wires through the motor mount arm section. It can be a bit tricky so have patience.
 {{:projects:crazyflie:mechanics:start_thread_wires_into_motor_mount.png?direct&300}} {{:projects:crazyflie:mechanics:start_thread_wires_into_motor_mount.png?direct&300}}
Line 56: Line 68:
 {{:projects:crazyflie:mechanics:all_wires_solderd_and_fixed.png?direct&300}} {{:projects:crazyflie:mechanics:all_wires_solderd_and_fixed.png?direct&300}}
-9. Attach the propellers (see drawings below for mapping). We recommend you sorting out the best propellers. [[http://wiki.bitcraze.se/projects:crazyflie:userguide:tips_and_tricks#maximizing_performance|See maximizing performance]]+9. Attach the propellers (see drawings below for mapping). You got two packs of them with your kit, containing 5 each of clockwise and counter-clockwise ones. Your clockwise propellers may be labeled with an "A", otherwise look at the curvature of the tips to determine which is CW and which is CCW. The dull surface goes up, the shiny surface goes down.  You will also see a small molded ring on the top surface.  We recommend you sorting out the best propellers. [[http://wiki.bitcraze.se/projects:crazyflie:userguide:tips_and_tricks#maximizing_performance|See maximizing performance]]
 {{:projects:crazyflie:mechanics:propeller_chart.png?direct&300}} {{:projects:crazyflie:mechanics:propeller_chart.png?direct&300}}
Line 67: Line 79:
 {{:projects:crazyflie:mechanics:attach_battery_centred.png?direct&300}} {{:projects:crazyflie:mechanics:attach_battery_centred.png?direct&300}}
-11. Before you power it on **visually inspect your soldering for shorts**. Make sure any copper from the wires are not sticking out so they could short to **either of the two resistors next to M3 or to anything else**. After that power on and check that all motors spin during start-up and in the correct direction.+11. Before you power it on **visually inspect your soldering for shorts**. Make sure any copper from the wires are not sticking out so they could short to **either of the two resistors next to M3 or to anything else**. You can also use a ohmmeter to check for a resistance of about 2 ohms between each pair of pads. After that power on (carefully push in the button with your fingernail - it is **not** a slide switch) and check that all motors spin during start-up and in the correct direction.
 {{:projects:crazyflie:mechanics:check_shorts.png?direct&300}} {{:projects:crazyflie:mechanics:check_shorts.png?direct&300}}
projects/crazyflie/mechanics/assembly.txt · Last modified: 2021-06-24 16:49 by kimberly
