What's in the packet
  • Crazyflie control board
  • 5 x CW propellers
  • 5 x CCW propellers
  • 1 LiPo battery
Tools you need
  • Soldering iron and solder
  • Scissors
What do you need to do
11. Before you power it on visually inspect your soldering for shorts. Make sure any copper from the wires are not sticking out so they could short to either of the two resistors next to M3 or to anything else. After that power on and check that all motors spin during start-up and in the correct direction.
Video
Motors and propellers
projects/crazyflie/mechanics/assembly.1367872758.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
