projects:crazyflie:mechanics:assembly [2013-05-17 05:39] jweather [What do you need to do] propeller "A" label on newer kits |
projects:crazyflie:mechanics:assembly [2015-07-15 16:31] 127.0.0.1 external edit |
Line 32: | Line 32: | ||
- | 2. Twist the two motor wires together so they are easier to handle | + | 2. Twist the two motor wires together so they are easier to handle |
Line 68: | Line 68: | ||
- | 9. Attach the propellers (see drawings below for mapping). Your propellers may be labeled with an " | + | 9. Attach the propellers (see drawings below for mapping). :!: You got two **different** packs of them with your kit, one with five clockwise and one with five counter-clockwise ones, take care to really use propellers from both packages, not just mounting two of them upside down, your drone won't fly otherwise :!:. Your clockwise |
Line 86: | Line 86: | ||
Assembly video using new motor mounts | Assembly video using new motor mounts | ||
{{youtube> | {{youtube> | ||
- | Old assembly video using 3D printed motor mounts | ||
- | {{youtube> | ||
