9. Attach the propellers (see drawings below for mapping). Your propellers may be labeled with an “A” for anti-clockwise, otherwise look at the curvature of the tips to determine which is CW and which is CCW. The dull surface goes up, the shiny surface goes down. You will also see a small molded ring on the top surface. We recommend you sorting out the best propellers. See maximizing performance
