User Tools
Site Tools
projects:crazyflie:mechanics:assembly
Differences
Link to this comparison view
Next revision
Previous revision
projects:crazyflie:mechanics:assembly [2013-05-17 05:39]
jweather [What do you need to do] propeller "A" label on newer kits
projects:crazyflie:mechanics:assembly [2021-06-24 16:49]
Line 1: Line 1:
 +</WRAP>
 ====== Assembly of the Crazyflie Micro Quadcopter Kit====== ====== Assembly of the Crazyflie Micro Quadcopter Kit======
 This page has details about how to assemble the Crazyflie nano quadcopter kit. This page has details about how to assemble the Crazyflie nano quadcopter kit.
Line 32: Line 35:
 {{:projects:crazyflie:mechanics:items_required.png?direct&300|}} {{:projects:crazyflie:mechanics:items_required.png?direct&300|}}
-2. Twist the two motor wires together so they are easier to handle+2. Twist the two motor wires together so they are easier to handle (and electromagnetic noise is reduced)
 {{:projects:crazyflie:mechanics:twist_motor_wires.png?direct&300}} {{:projects:crazyflie:mechanics:twist_motor_wires.png?direct&300}}
Line 68: Line 71:
 {{:projects:crazyflie:mechanics:all_wires_solderd_and_fixed.png?direct&300}} {{:projects:crazyflie:mechanics:all_wires_solderd_and_fixed.png?direct&300}}
-9. Attach the propellers (see drawings below for mapping). Your propellers may be labeled with an "A" for anti-clockwise, otherwise look at the curvature of the tips to determine which is CW and which is CCW.  The dull surface goes up, the shiny surface goes down.  You will also see a small molded ring on the top surface.  We recommend you sorting out the best propellers. [[http://wiki.bitcraze.se/projects:crazyflie:userguide:tips_and_tricks#maximizing_performance|See maximizing performance]]+9. Attach the propellers (see drawings below for mapping). :!: You got two **different** packs of them with your kit, one with five clockwise and one with five counter-clockwise ones, take care to really use propellers from both packages, not just mounting two of them upside down, your drone won't fly otherwise :!:. Your clockwise propellers may be labeled with an "A", otherwise look at the curvature of the tips to determine which is CW and which is CCW. The dull surface goes up, the shiny surface goes down. You will also see a small molded ring on the top surface. We recommend you sorting out the best propellers. [[http://wiki.bitcraze.se/projects:crazyflie:userguide:tips_and_tricks#maximizing_performance|See maximizing performance]]
 {{:projects:crazyflie:mechanics:propeller_chart.png?direct&300}} {{:projects:crazyflie:mechanics:propeller_chart.png?direct&300}}
Line 86: Line 89:
 Assembly video using new motor mounts Assembly video using new motor mounts
 {{youtube>KeqiUPIDpV8}} {{youtube>KeqiUPIDpV8}}
-Old assembly video using 3D printed motor mounts
-{{youtube>kS3qR1IjeGE }}
projects/crazyflie/mechanics/assembly.txt · Last modified: 2021-06-24 16:49 by kimberly
