projects:crazyflie:pc_utils:inputdevices [2013-05-24 13:32] macke |
projects:crazyflie:pc_utils:inputdevices [2015-07-15 16:31] 127.0.0.1 external edit |
====== Input-devices for the Crazyflie client ====== | ====== Input-devices for the Crazyflie client ====== | ||
- | The Crazyflie graphical control client needs an input-device (joystick) with a minimum of 4 analogue | + | The Crazyflie graphical control client needs an input-device (joystick) with a minimum of 4 analogue |
===== Limitations ===== | ===== Limitations ===== | ||
Line 11: | Line 11: | ||
* The input-device needs to be recognized by the host operating system. This means that it should be seen in the operating system and be usable in other applications or utilities. | * The input-device needs to be recognized by the host operating system. This means that it should be seen in the operating system and be usable in other applications or utilities. | ||
* When using the Crazyflie graphical control client you need at least the correct mappings for roll/ | * When using the Crazyflie graphical control client you need at least the correct mappings for roll/ | ||
+ | * If you aren't getting any output at all and you are using the Playstation 3 controller, then press the " | ||
* If the mappings are not correct in the previous point go to the menu // | * If the mappings are not correct in the previous point go to the menu // | ||
Line 18: | Line 19: | ||
Below is a list of controllers and the status for different OSs. The list is far from complete so if you have more info please edit or drop us an email. | Below is a list of controllers and the status for different OSs. The list is far from complete so if you have more info please edit or drop us an email. | ||
- | ^ **Controller** | + | ^ **Controller** |
- | | Playstation 3 (or copy) | Works | [[projects: | + | | Playstation 3 (or copy) | Works | [[projects: |
- | | Xbox 360 (or copy) | [[projects: | + | | Xbox 360 (or copy) | [[projects: |
====== Playstation 3 controller ====== | ====== Playstation 3 controller ====== | ||
===== Linux using Bluetooth ===== | ===== Linux using Bluetooth ===== | ||
- | **TODO** | + | [[https:// |
===== WinXP using Bluetooth===== | ===== WinXP using Bluetooth===== | ||
**TODO** | **TODO** | ||
- | ===== Win7 ===== | + | ===== Win7 using USB===== |
- | ==== USB ==== | + | |
There' | There' | ||
[[http:// | [[http:// | ||
- | ==== Bluetooth ==== | + | ===== Win7 using Bluetooth |
Should work using MotionJoy but this needs confirmation. | Should work using MotionJoy but this needs confirmation. | ||
===== Mac OSX with Bluetooth ===== | ===== Mac OSX with Bluetooth ===== | ||
Line 40: | Line 40: | ||
====== Xbox 360 controller ====== | ====== Xbox 360 controller ====== | ||
===== Linux using USB ===== | ===== Linux using USB ===== | ||
- | **TODO** | + | |
+ | If you are having problems getting this to work (or you are using the wireless version) then the userspace driver '' | ||
+ | sudo apt-get install xboxdrv | ||
+ | And then started by running: | ||
+ | sudo xboxdrv | ||
+ | More info about the '' | ||
