| Controller | Linux USB | Linux BT | Win XP USB | Win XP BT | Win7 USB | Win7 BT | Mac OSX USB | Mac OSX BT |
| Playstation 3 (or copy) | Works | Instructions? | Works | Instructions? | Motion joy instructions? | Motion joy instructions? | Works | Instructions |
| Xbox 360 (or copy) | Instructions? | N/A | Works | N/A | Works | N/A | Not tested | Not tested |
