projects:crazyflie:pc_utils:install [2013-04-28 19:32] arnaud [Running source code on Windows] |
projects:crazyflie:pc_utils:install [2015-09-10 11:00] (current) macke |
| - | ====== Crazyflie PC client installation ====== | + | In the interest of not duplicating instructions all the install |
| - | The Crazyflie PC utilities are developed using Python 2.7. The Crazyflie library is used from the command line tools as well as a graphical user interface. On Windows an installer permits to run the client without having to install | + | |
| - | ===== Installing on windows ===== | + | |
| - | Download and run the installer from the [[projects: | + | |
| - | To install the Crazyradio dongle follow the instruction [[projects: | + | |
| - | ===== Installing on Linux ===== | + | |
| - | The following has to be installed for the PC utilities to work: | + | |
| - | * Python 2.7 | + | |
| - | * pyGame | + | |
| - | * PyUSB (0.X or 1.X) | + | |
| - | * libusb | + | |
| - | For the graphical userinterface to work the following is also needed: | + | |
| - | * Python bindings for Qt4 | + | |
| - | ==== Fedora ==== | + | |
| - | The following has been tested on Fedora 16. Note that this will pull in a lot of dependencies. | + | |
| - | sudo yum install pygame pyusb PyQt4 | + | |
| - | ==== Ubuntu ==== | + | |
| - | The following has been tested on Ubuntu 10.04/ | + | |
| - | sudo apt-get install python2.7 python-usb python-pygame python-qt4 | + | |
| - | ==== Fix udev premissions on Linux ==== | + | |
| - | In order to fix the permissions so it's possible to use the USB Radio without being root do the following steps. | + | |
| - | sudo groupadd plugdev | + | |
| - | sudo usermod -a -G plugdev < | + | |
| - | Create a file named / | + | |
| - | SUBSYSTEM==" | + | |
| - | Restart the computer and you are now able to access the USB radio dongle without being root. | + | |
| - | ===== Running source code on Windows ===== | + | |
| - | This procedure is required if you want to develop with the Crazyflie client on Windows. If you just want to run and fly the Carzyflie follow the instruction to install the client above. | + | |
| - | ==== Windows XP ==== | + | |
| - | The following has to be downloaded/ | + | |
| - | * [[http://www.python.org/download/releases/ | Python 2.7]] (for Windows the last available binary version of Python 2.7 is [[http:// | + | |
| - | * [[http:// | + | |
| - | ==== Windows Vista/7 32/ | + | |
| - | Even if you have a 64-bit install you should download the 32-bit versions of the libraries since this makes everything easier. | + | |
| - | ===== Installing on Mac OSX ===== | + | |
| - | **TODO** | + | |
