Installing on windows
To install the Crazyradio dongle follow the instruction Install crazyradio driver on Windows 7. This procedure is similar for windows XP to 8.
Installing on Linux
  • Python 2.7
  • pyGame
  • PyUSB (0.X or 1.X)
  • libusb
  • Python bindings for Qt4
Fedora
Ubuntu
Fix udev premissions on Linux
sudo groupadd plugdev
Windows XP
Windows Vista/7 32/64-bit
Installing on Mac OSX
projects/crazyflie/pc_utils/install.1367170341.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
