User Tools
Site Tools
projects:crazyflie:pc_utils:raspberrypi
Differences
Link to this comparison view
projects:crazyflie:pc_utils:raspberrypi [2017-05-22 11:45]
projects:crazyflie:pc_utils:raspberrypi [2021-06-24 16:47] (current)
Line 1: Line 1:
 +</WRAP>
 ====== Modifying the Raspian Wheezy image ====== ====== Modifying the Raspian Wheezy image ======
 Here's a step by step guide to what we added. So if you don't want to use our image, you can get another one and set it up yourself. Most of this stuff is based of the contributed instructions from the [[misc:hacks:rasberrypi|hacks section]]. Here's a step by step guide to what we added. So if you don't want to use our image, you can get another one and set it up yourself. Most of this stuff is based of the contributed instructions from the [[misc:hacks:rasberrypi|hacks section]].
projects/crazyflie/pc_utils/raspberrypi.txt · Last modified: 2021-06-24 16:47 by kimberly
