Note Since version 2015.3 you can setup your own SDCard in one command.
Info All modern Linux distribution now have a kernel driver for the x-box gamepad. Thus it is unlikely the xboxdrv user-space driver is needed.
Lets install everything that we might need fro running the Crazyradio, controllers and the headless client.
sudo apt-get -y install python-usb xboxdrv
sudo touch /etc/udev/rules.d/99-crazyflie.rules sudo nano /etc/udev/rules.d/99-crazyflie.rules
In order for the Xbox 360 wireless controller to work the xboxdrv utility has to be installed and launched when the controller is connected. So add a new udev rule for this.
sudo nano /etc/udev/rules.d/99-xboxdrv.rules
Put the following into the text file:
sudo mkdir /root/bin/ sudo touch /root/bin/cfheadless sudo chmod +x /root/bin/cfheadless sudo nano /root/bin/cfheadless
And add the following text:
#!/bin/sh
if test "$ACTION" = "add"
then
/usr/bin/sudo -u bitcraze /home/bitcraze/start_cfheadless &
echo $! > /tmp/cfheadless.pid
else
killall -9 cfheadless
then
PID=`cat /tmp/cfheadless.pid`
kill -9 $PID
fi
fi
sudo touch /root/bin/xbox360 sudo chmod +x /root/bin/xbox360 sudo nano /root/bin/xbox360
#!/bin/sh
then
/usr/bin/xboxdrv &
else
killall -9 xboxdrv
fi
Go to the pi users home directory and clone the PC client and Crazyradio firmware projects.
cd mkdir projects cd projects git clone https://github.com/bitcraze/crazyflie-clients-python.git
Create the script that will execute when the Crazyradio is inserted. This will launch the cfheadless client.
cd touch start_cfheadless chmod +x start_cfheadless nano start_cfheadless
Insert the following text into the file:
/home/pi/projects/crazyflie-clients-python/bin/cfheadless -u `cat /home/pi/link.conf` -i `cat /home/pi/controller.conf` > /tmp/cfheadless.log 2>&1
Now the last part, the configuration. The script above will launch the cfheadless client with the controller and link configuration that is written in the two files 'controller.conf' and 'link.conf'. This configuration is written using the following commands:
echo PS3_Mode_1 > /home/pi/controller.conf echo radio://0/10/250K > /home/pi/link.conf
If you are using another controller configuration or another link, just use the same commands as above but replace it with your own settings.
That's it! Now you can connect the controller, start the Crazyflie and insert the Crazyradio and you are ready to fly.
update_on_pi_release
