projects:crazyflie:upgrading:index [2015-03-23 11:35] tobias |
projects:crazyflie:upgrading:index [2015-07-15 16:31] 127.0.0.1 external edit |
+ | ====== Upgrading/ | ||
+ | There are currently two ways to flash the Crazyflie Nano | ||
+ | ==== Upgrade/ | ||
+ | The Crazyflie Nano contains a bootloader with which it can be updated over the air (OTA). Either using the cfclient or from command line. | ||
+ | * [[doc: | ||
+ | * [[projects: | ||
+ | This is mainly for development and requires a JTAG debugger with ARM Cortex 10-pin interface. | ||
