User Tools
Site Tools
projects:crazyflie:upgrading:index
Differences
Link to this comparison view
Next revision
Previous revision
projects:crazyflie:upgrading:index [2015-03-23 11:46]
tobias [Upgrade/flash using a JTAG degugger/flasher]
projects:crazyflie:upgrading:index [2015-07-15 16:31]
127.0.0.1 external edit
Line 1: Line 1:
 +====== Upgrading/flashing the Crazyflie Nano (1.0) ======
 +There are currently two ways to flash the Crazyflie Nano
 +==== Upgrade/flash using the Crazyradio or Crazyradio PA ====
 +The Crazyflie Nano contains a bootloader with which it can be updated over the air (OTA). Either using the cfclient or from command line.
 +  * [[doc:crazyflie:client:pycfclient:index#bootloader|Upgrading using the cfclient]]
 +  * [[projects:crazyflie:devenv:index#compiling_the_copter_code|Upgrading using the make environment]]. Convenient for developers. This is also available as a make target in Eclipse in the [[projects:virtualmachine:index|VM]].
 +==== Upgrade/flash using a JTAG degugger/flasher ====
 +This is mainly for development and requires a JTAG debugger with ARM Cortex 10-pin interface.
 +  * [[projects:virtualmachine:jtag_debug|Virtual Machine JTAG debug]]
projects/crazyflie/upgrading/index.txt · Last modified: 2021-06-24 16:53 by kimberly
