User Tools
Site Tools
projects:crazyflie:userguide:index
Differences
Link to this comparison view
Next revision
Previous revision
projects:crazyflie:userguide:index [2013-05-06 19:15]
skube [Flying]
projects:crazyflie:userguide:index [2014-02-18 14:42]
tobias [LED indications]
Line 12: Line 12:
   * [[projects:crazyradio:index|A Crazyradio USB dongle]]   * [[projects:crazyradio:index|A Crazyradio USB dongle]]
   * [[projects:crazyflie:pc_utils:qt_ui|A PC side application for controlling the quadcopter]]   * [[projects:crazyflie:pc_utils:qt_ui|A PC side application for controlling the quadcopter]]
-  * A controller for input of flight commands (joystick). **Currently only PlayStation compatible input devices are well supported.**+  * A controller for input of flight commands (joystick). Currently Playstation and Xbox 360 controllers are supported out of the box, but any controller with at least 4 analog axis can be configured and used. Se the [[projects:crazyflie:pc_utils:inputdevices|input-device]] page for more information.
 ===== Basic concepts ===== ===== Basic concepts =====
Line 19: Line 19:
 ==== Flying ==== ==== Flying ====
-The Crazyflie has 4 different controls: roll, pitch, yaw and thrust. Changing the roll and pitch will make the quadcopter tilt to the sides and thus change the direction that it's moving in. Tilting the quadcopter forward will make it go forward and the same applies for every other direction.
-{{:projects:crazyflie:userguide:crazyflie_directions_pitch_roll.jpg?direct&250|}}+The Crazyflie has 4 different controlsroll, pitch, yaw and thrust.
 +Changing the roll and pitch will make the quadcopter tilt to the sides and thus change the direction that it's moving in. Tilting the quadcopter forward will make it go forward and the same applies for every other direction.  **Note**the images below show the front as setup in X configuration. Normal (out of the box) configuration has the front inline with motor M1.
-Changing the yaw will make the quadcopter spin. Changing the yaw is normally not a good idea for beginners since this will also change what direction is forward for the quadcopter.+{{:projects:crazyflie:userguide:crazyflie_directions_pitch_roll.jpg?direct&250|[pitch,roll & foward]}}
-{{:projects:crazyflie:userguide:crazyflie_directions_thrust_yaw.jpg?direct&250 |}}+{{:projects:crazyflie:userguide:crazyflie_directions_thrust_yaw.jpg?direct&250 |[yaw and "front" orientation changing]}} Changing the yaw will make the quadcopter spin. Changing the yaw is normally not a good idea for beginners since this will also change what direction is forward for the quadcopter.
 The thrust is used to control the altitude of the quadcopter. The thrust is used to control the altitude of the quadcopter.
 ==== Radio communication ==== ==== Radio communication ====
 The frequency used communication is based on 2.4 GHz. For every quadcopter it's possible to set a channel between 0-127 (only 0-80 is allowed worldwide) that will be used for communication. This means that once the channels is set for a quadcopter you will have to specify the appropriate channel when communicating with it. The channel can be set within the service tab of the Crazyflie client pc-program. The frequency used communication is based on 2.4 GHz. For every quadcopter it's possible to set a channel between 0-127 (only 0-80 is allowed worldwide) that will be used for communication. This means that once the channels is set for a quadcopter you will have to specify the appropriate channel when communicating with it. The channel can be set within the service tab of the Crazyflie client pc-program.
 ===== Durability ===== ===== Durability =====
-The Crazyflie is contructed without a separate frame, it uses the PCB as a frame and simply attaches four motors to it. This means that the weight of the platform is very low and on most impacts it simply bounces of objects. If you are unlucky either propellers or motors might break when crashing. If so have a look at our [[projects:crazyflie:userguide:troubleshooting|troubleshooting page]] for some basic troubleshooting and repairs. If you are very unlucky due to a really severe crash you might break one of the PCB arms. We are working on a 3D printed plastic patch that could fix this. +The Crazyflie is contructed without a separate frame, it uses the PCB as a frame and simply attaches four motors to it. This means that the weight of the platform is very low and on most impacts it simply bounces of objects. If you are unlucky either propellers or motors might break when crashing. If so have a look at our [[projects:crazyflie:userguide:troubleshooting|troubleshooting page]] for some basic troubleshooting and repairs. If you are very unlucky due to a severe crash you might break one of the PCB arms. We are working on a 3D printed plastic patch that could fix this. **Either way handle the Crazyflie with care as it is not unbreakable**
 ====== Basic usage ====== ====== Basic usage ======
 ===== Getting started ===== ===== Getting started =====
-  * Power it on by pressing the power button+  * Power it on by pressing the side-mounted push-button
   * Hold the Crazyflie stable during the start-up, otherwise the sensor tests may not pass. Each motor will quickly turn on to indicate that they are working.   * Hold the Crazyflie stable during the start-up, otherwise the sensor tests may not pass. Each motor will quickly turn on to indicate that they are working.
   * Place the Crazyflie on a stable surface (the floor is the best)   * Place the Crazyflie on a stable surface (the floor is the best)
Line 58: Line 56:
   - Blue LED - Shows power on status   - Blue LED - Shows power on status
   - Expansion - Can be used to expand functionality by adding hardware   - Expansion - Can be used to expand functionality by adding hardware
-  - Power button - Powers on/off+  - Power push-button - Push button to switch the Crazyflie on/off (**Note that this is a push button, not a sliding button**)
   - Front direction when flying in normal configuration   - Front direction when flying in normal configuration
-  - Front direction when flying in X configuration+  - Front direction when flying in X configuration, blue LED is at the tail.
Line 68: Line 66:
 The Crazyflie has four LEDs mounted, two blue, one red and one green. The two blue LEDs indicate that the system is powered and the red/green shows operation. The Crazyflie has four LEDs mounted, two blue, one red and one green. The two blue LEDs indicate that the system is powered and the red/green shows operation.
-During startup+When the Crazyflie is powered the two blue LEDs will be lit up and the red/gren LED will blink shortly indicating that the bootloader is executing. After this the firmware will start up.
 +During firmware startup:
   * Green LED   * Green LED
     * **Tests passed:** 5 quick flashes     * **Tests passed:** 5 quick flashes
   * Red LED   * Red LED
-    * **Tests failed:** 5 quick flashes+    * **Tests failed:** 5 quick flashes. This can be caused by too much movement of the Crazyflie when powering it on. Try putting it on a stable surface and try again.
 When USB is connected: When USB is connected:
Line 92: Line 92:
 All these behaviours can be compile time configured. In the future they might as well be able configurable during runtime using the Crazyflie client. All these behaviours can be compile time configured. In the future they might as well be able configurable during runtime using the Crazyflie client.
   * **Radio communication lost**   * **Radio communication lost**
-    * If the Crazyflie hasn'revieved any commander package within 0.5s it will try to level itself. The client sends out 100 control packets per second so 50 consecutive packages must have been lost +    * If the Crazyflie hasn'received any commander package within 0.5s it will try to level itself. The client sends out 100 control packets per second so 50 consecutive packages must have been lost
-    * If the Crazyflie hasn'revieved any commander package within 2s it will turn off the all motors.+    * If the Crazyflie hasn'received any commander package within 2s it will turn off the all motors.
   * **Inactivity shutdown**   * **Inactivity shutdown**
-    * If the Crazyflie hasn'revieved any commander package within 5min it will automatically shut down.+    * If the Crazyflie hasn'received any commander package within 5min it will automatically shut down.
 ===== The USB Radio dongle ===== ===== The USB Radio dongle =====
Line 103: Line 103:
   - Programming/PPM interface - Used for programming and interfacing with a RC remote   - Programming/PPM interface - Used for programming and interfacing with a RC remote
   - Antenna connector - Connector for antenna   - Antenna connector - Connector for antenna
-  - Red LED - Toggles when data is no able to be sent to the quadcopter+  - Red LED - Toggles when data is now able to be sent to the quadcopter
   - Green LED - Toggles when data is successfully send to the quadcopter    - Green LED - Toggles when data is successfully send to the quadcopter
projects/crazyflie/userguide/index.txt · Last modified: 2021-06-24 16:53 by kimberly
