projects:crazyflie:userguide:index [2013-05-06 19:19] skube [Flying] |
projects:crazyflie:userguide:index [2015-01-29 14:17] 192.3.55.160 Links adapted because of a move operation |
- | ====== Introduction ====== | ||
- | ===== What is the Crazyfile Nano Quadcopter used for ===== | ||
- | It can be used for a number of things but the primary usage is as a development platform and for quadcopter enthusiasts that would like a nano-quad. Here's a list of some possible uses: | ||
- | * Implementing and testing control algorithms | ||
- | * Adding functionality using the expansion interface | ||
- | * Creating applications on the host side that control the quadcopter | ||
- | * Help us out with implementing new features and finding/ | ||
- | ===== What do you need for flying ===== | ||
- | Here's a short list of what is needed for flying: | ||
- | * [[projects: | ||
- | * A controller for input of flight commands (joystick). **Currently only PlayStation 3 compatible input devices are well supported.** | ||
- | ===== Basic concepts ===== | ||
- | The Crazyflie is controlled from a computer using an input device such as a game controller (PS3 or Xbox 360). A USB radio dongle is used to send control data from the controller/ | ||
- | ==== Flying ==== | ||
- | The Crazyflie has 4 different controls: roll, pitch, yaw and thrust. Changing the roll and pitch will make the quadcopter tilt to the sides and thus change the direction that it's moving in. Tilting the quadcopter forward will make it go forward and the same applies for every other direction. | ||
- | Changing the yaw will make the quadcopter spin. Changing the yaw is normally not a good idea for beginners since this will also change what direction is forward for the quadcopter. | ||
- | The thrust is used to control the altitude of the quadcopter. | ||
- | ==== Radio communication ==== | ||
- | The frequency used communication is based on 2.4 GHz. For every quadcopter it's possible to set a channel between 0-127 (only 0-80 is allowed worldwide) that will be used for communication. This means that once the channels is set for a quadcopter you will have to specify the appropriate channel when communicating with it. The channel can be set within the service tab of the Crazyflie client pc-program. | ||
- | ===== Durability ===== | ||
- | The Crazyflie is contructed without a separate frame, it uses the PCB as a frame and simply attaches four motors to it. This means that the weight of the platform is very low and on most impacts it simply bounces of objects. If you are unlucky either propellers or motors might break when crashing. If so have a look at our [[projects: | ||
- | ====== Basic usage ====== | ||
- | ===== Getting started ===== | ||
- | * Power it on by pressing the power button | ||
- | * Hold the Crazyflie stable during the start-up, otherwise the sensor tests may not pass. Each motor will quickly turn on to indicate that they are working. | ||
- | * Place the Crazyflie on a stable surface (the floor is the best) | ||
- | * Wait until the red LED shows that the sensors are calibrated by increasing the blink rate from 1Hz to 2Hz. | ||
- | * Connect to the quadcopter using the [[projects: | ||
- | * The green LED will now start flashing indicating that the radio communication is working | ||
- | * Use the controller to control the movement of the quadcopter | ||
- | * Fly around :) | ||
- | * When the red LED is continuously lit or/and the copter becomes uncontrollable the battery is low. Recharge and start over. | ||
- | For more tips on flying take a look at the [[projects: | ||
- | ===== The Crazyflie ===== | ||
- | Below are the basic components mapped out on the Crazyflie. | ||
- | {{: projects: | ||
- | - Red LED - Shows system alive and charge status | ||
- | - Green LED - Shows radio communication and charging status. | ||
- | - Blue LED - Shows power on status | ||
- | - Expansion - Can be used to expand functionality by adding hardware | ||
- | - Power button - Powers on/off | ||
- | - Front direction when flying in normal configuration | ||
- | - Front direction when flying in X configuration | ||
- | - uUSB charging - Used to charge the battery | ||
- | ==== LED indications ==== | ||
- | The Crazyflie has four LEDs mounted, two blue, one red and one green. The two blue LEDs indicate that the system is powered and the red/green shows operation. | ||
- | During startup | ||
- | * Green LED | ||
- | * **Tests passed:** 5 quick flashes | ||
- | * Red LED | ||
- | * **Tests failed:** 5 quick flashes | ||
- | When USB is connected: | ||
- | * **Charging: | ||
- | * **Fully charged:** LED steady lit | ||
- | * Red LED | ||
- | * **System alive:** 1 Hz heart beat | ||
- | When USB is not connected: | ||
- | * **Radio communication: | ||
- | * Red LED | ||
- | * **Sensors calibrated: | ||
- | * **Charging needed:** Red LED steadily lit. "Fly back to base!" | ||
- | ==== Firmware behaviour ==== | ||
- | All these behaviours can be compile time configured. In the future they might as well be able configurable during runtime using the Crazyflie client. | ||
- | * **Radio communication lost** | ||
- | * If the Crazyflie hasn't revieved any commander package within 0.5s it will try to level itself. The client sends out 100 control packets per second so 50 consecutive packages must have been lost | ||
- | * If the Crazyflie hasn't revieved any commander package within 2s it will turn off the all motors. | ||
- | * **Inactivity shutdown** | ||
- | * If the Crazyflie hasn't revieved any commander package within 5min it will automatically shut down. | ||
- | ===== The USB Radio dongle ===== | ||
- | - USB - Connect to computer | ||
- | - Programming/ | ||
- | - Antenna connector - Connector for antenna | ||
- | - Red LED - Toggles when data is no able to be sent to the quadcopter | ||
- | - Green LED - Toggles when data is successfully send to the quadcopter |
